Corsair H80i GT LED Color Doesnt Change and is Not Showing up in Corsair LINK
HudsonGTV
29
I am a Windows 10 user and can not change the LED color of the Corsair H80i GT. It doesn't even look like it detects the cooler even though its plugged in and working. I watched this video (https://www.youtube.com/watch?v=5uBCLYmgcDo) on fixing it in the registry edit, but was unable to find the "file" it was telling you to modify. Here's a screenshot of my registry page: http://imgur.com/F9yocb4
How would I fix this? If you need more specs on my desktop, let me know. Thanks!
There would have been a USB cable in the box. Make sure that you installed all of the cables correctly as per the instruction manual.
If you are still having issues, try the following:
1: Completely uninstall Corsair Link
2: Unplug the USB and power headers from the motherboard
3: Plug the power header back in
4: Plug the USB header back in, using a different USB header this time
5: Re-download Corsair Link (this ensures you have the latest version)
6: Install Corsair Link
