Corsair H90 Cooler Question
SniiKz
110
Is it possible to install the Corsair H90 without the back brackets? The brackets that go behind the motherboard, my friend recently gave me his hand me down H90 and I have the proper socket and screws, but no back plate. If not, is there a possible way to build the back plate, or buy another one?
Thanks!
1. you can order backplate (and you really should)
2. for now, you can use some plastic washers between screws and MB. just don't use too much force when tightening as it might bend the MB
Where would I order the backplate from, I would also probably need more screws and the part that locks in the watercooler to the frame thingy?
