[SOLVED] Corsair HX650 power supply fan noise
brkenamfioso
35
I have a 2nd hand Corsair HX650 power supply. The fan makes a noise.
Here is a link to how it sounds. Apparently this is a common issue with this model.
https://www.youtube.com/watch?v=U9RLln5g2VI
Has anyone been able to solve this issue? I cant rma as it is 2nd hand and no warranty.
Is the fan replaceable/repairable and if so what fan would I replace it with.
stevenjemint
Notable
Aug 13, 2018
784
143
You could replace the fan, i couldnt find one online though. You could check ebay for a dead Corsair PSU and swap the fans.
I imagine any fan that range (HX) will fit as long as the PSU dimensions match.
You could contact Corsair and ask if they could supply you one or at least advise what PSUs they used them in.
stevenjemint
Notable
Aug 13, 2018
784
143
