Gday
Currently i'm running an Gigabyte Aorus 1080Ti Xtreme (not overclocked) single 8pin to 2x8pin PCIe cable supplied by the power supply. Read a current ongoing thread regarding the use of these. When i first searched about it back then, some said its fine, and others saying it's better to use two separate cables. It's been running fine but I'm not entirely sure now if there may be underlying issues that may arise.
I can just add another cable i guess but didn't like the shape of these flat cables though and it was kinda awkward having two which i initially did try both cables but for cable management ended up using just one.
Rest of of my specs
2600k @ 4.5
P8P67 Delux mobo
32GB 1600 ram (4x 8GB)
1TB Sata SSD
1TB 7200 HDD
Optical disc
Corsair HX750i (roughly 4months old)
Am i okay to continue with 8 to 2x 8pin PCIe with this power supply? Are the cables properly rated?
Thanks.
Rest of of my specs
2600k @ 4.5
P8P67 Delux mobo
1TB Sata SSD
1TB 7200 HDD
Optical disc
Thanks.
