Question Corsair iCue H150i radiator second, 11 pin connector goes where?
D
Deleted member 2783327
Guest
You should have a 3 pin pump header, 3 x 4 pin fan headers and the large flat connector goes to a sata power cable.
Aug 26, 2022
45
I have the 3 pin onto the cpu pump. The AIO itself only has one other cable that won't plug into any of the sata cables that came with my PSU. It kinda looks like the sort of cable that would go into the motherboard but nothing matches it.
edit:It goes into the Commander Core. 😅
