Question Corsair K100 spacebar issue?
frozensun
303
7
18,695
Hi guys.
Got it used but I am having an issue with spacebar key.
Every third fourth pressure on the key is registered,sometimes not even 5 clicks.
Is there something I could do from home?
There was some dust under key which I cleaned but still same issue.
Nothing seems broken.
Hmm now I see that key press is registered when I press spacebar at either left or right side of the spacebar.
What could that mean?
The switch is probably going bad, you can use some contact cleaner and it might fix it, I personally use wd-40 for stuff like this, it acts like a contact cleaner and a lube, sorta dab it in and work it in, though they do make a lube for keyboards but its not a contact cleaner.
Good Luck!
