Corsair K60 changes how keys work randomly
ninjabot553
52
Some times when I use my corsair k60, all of the keys on my keyboard began doing weird stuff.
A example is hitting the "s" key to bring up the search charm on windows 8.1.
Also the only letter that works is a while typing .
I need a Answer to this problem please.
This happens too on my Cooler Master Storm Quickfire TK. Sometimes when I press S, it presses windows + s which leads to the search bar on the right. When i press R, it opens the run window (which is Window + R). I'm not quite sure on this issue but Cooler Master is aware of this problem and others have this problem as well. Most of the time it disappears if you wait it out. By any chance do you have the Lock Windows Key enabled?
I dont, should i replace my keyboard because it locks up to 30 minutes of maximum time?
