Corsair K70/95 programming help.
therobin9810
80
Hello! is there anybody who knows the capabilities of personalizing the corsair k95 keyboard?
To be a bit more clear... I am a 3D artist working in a program called 3ds Max, is there a way that i can manipulate my keyboard (K95) to swap between the left ALT key and the Spacebar key. essentially manipulating the keyboard to use left alt when i press spacebar... doesn't have to be vice versa tbh. Thank you for any help!
Sorry for not getting back to you sooner.. I tested it and unfortunately, our legacy gaming software does not support remapping standard keys other than the Macro G keys.
And just to be sure, you have a K95 non-RGB right?
therobin9810
80
If you do test it i am very thankful! :)
CorsairJoseph
300
therobin9810
80
Sorry, i should have been clearer... I do have the RGB version of the K95, will that change anything?
*EDIT* I did it "just right clicked on spacebar and chose "Remap key" and chose LAlt, (Same to LAlt) really awesome that you could do that, gratz to corsair! really awesome. And thanks for the quick support really shows that corsair cares!
CorsairJoseph
300
No problem at all :) Glad to hear that you were able to sort it out.. and thanks for sharing your feedback.
If you haven't already seen it, you can check out some cool Lighting profiles for your K95 RGB here, http://gaming.corsair.com/en-us/rgbshare/hall-of-fame. Enjoy your KB!
