Corsair K70 how to turn off caps lock light indicator?
Klossel
28
Question is in the title but basically the light indicator for the caps lock is really distracting in game as I have key binds to caps lock so I wanted know if there's anyway of turning this feature off? Looked everywhere in the software but can'r find the option to disable it.
It's likely baked into the hardware and can't be disabled with software.
Take a small piece of electrical tape and cover the light - probably the easiest thing you can do that's easily reversible.
