Hiya,
I have 2x HD120 rgb fans (Corsair) and the lightning Node Pro, the node only has 2 led plugs, each fan has 2 cables (pwr/rgb) - Would it be ok to plug the pwr cable into the motherboard fan header and then the rgb cable into the pro? Just wondering if I would need an additional fan hub if i'm only using 2 fans
