[SOLVED] Corsair LL RGB FAN with Gigabyte RGB Fusion
ahmedcs1985
Proper
Mar 6, 2018
54
Hey all i just got a new build unfortunately im facing few problem with RGB
i bought corsair LL rgb fan single kit and i didn't know that it have to work with controller so right now its not working as rgb fan with any lights at all
i want to know is there RGB fusion compatible RGB fan that can work without controller / hub
and 2nd option is there anyway to make this fan work as RGB Fan and if i must buy a ARGB controller / hub which one you suggest with lowest price that would fit with this fan
so what i could do is there any ARGB fan that could be installed without hub and will be compatible with fusion
That part ... I don't know, tbh. I have all Corsair stuff, personally, and know their stuff quite well. Beyond that, I'm not sure.
