What CPU you do have in use? Since different CPUs have different heat production, especially when you've OCd your CPU. Also, what is your ambient temp and how good of a airflow you have in your PC case?
I have i5-6600K at stock clocks (3.5 Ghz base, 3.9 Ghz turbo) with C-Steps enabled in BIOS, which clocks the CPU depending on its usage (e.g when CPU idles, it's speed fluctuates between 800 Mhz and 1.1 Ghz). It saves a lot of energy and also extends the CPU lifespan considerably.
Also, my ambient temp is 26.6°C and with air cooling or AIO in use, you can not get your temps below ambient. Only way do get lower than ambient temps is to use
LN2 cooling.
Of course, i have very solid airflow in my Corsair 760T V2 Black full-tower ATX case as well, in form of:
2x 140mm front intake fans (Corsair ML140 Pro (red LED))
1x 120mm bottom intake fan (Corsair ML120 Pro (red LED))
3x 140mm top exhaust fans (NZXT AER140 RGB)
1x 140mm rear exhaust fan (Corsair ML140 Pro (red LED))
All fans, except bottom 120mm intake are hooked to the external 5.25" fan controller (Thermaltake Commander F6 RGB) for me to control their RPM with a simple turn of a knob. I have all my case fans running at 1000-1100 RPM for the best balance between noise and airflow.
And since my setup is tuned towards negative pressure, it offers the best cooling performance compared to the neutral or positive pressure. Downside is that a more dust would enter the system but i've countered it with high-end Demciflex custom filter kit, so, dust isn't an issue for me.
While your Zalman 10X Optima heatsink dimensions are very close to my Arctic Freezer i32 heatsink dimensions, thermal paste can also give that temperature difference. I'm using Arctic MX-4 thermal paste with my setup.
