Hello
I recently prepared a new gaming rig with;
Case: NZXT Manta
Motherboard: Asrock Ab350 Gaming ITX
GPU: MSI GTX 1080 Armor OC
CPU: AMD Ryzen 5 1600 (Stock Fan)
While gaming gpu heat goes around 75-78 degree and i want to see it cooler. But i dont want to take gpu's cooler out and put aio cooler to not to void the warranty. So i decided to improve case airflow with some aftermarket fans. (Dont know how much advantage do i get with this method tho)
Besides, cpu is overclocked at 3.6 ghz and in stability test i see 64 degree of temperatures. Not bad with stock fan but i want to add a liquid cooler..
I choosed Corsair ML120 pro led model as fans for case and NZXT Kraken x52 for cpu.
My question is: Fan controller of case can control 7 fans but they are 3 pins of connectors. May i control those corsair ml120 4 pin pwm fans with this controller?
Second question: Will NZXT Kraken x52 have problems about connections with my mobo, case controller or those fans?
Thanks
Case: NZXT Manta
Thanks
