Corsair ML Led Fans Brightness
S_A_N_D_M_A_N
Commendable
Dec 15, 2016
5
Good Day,
I just build a new pc with 6 of corsair new ml white led fans, but when the fans spin slowly they are dim and if they spin faster they get much brighter. I would like them to stay at full brightness at all times regardless of fan speed. My Asus z170 Premium motherboard has 6 pwm fan headers and I used all of the 4 pin pwm fan headers to connect my fans. So I am sure that I am using the correct pwm fan headers. My only thought is that it should be a setting in the motherboard bios to enable pwm mode of something? Please any advice would be appreciated.
Thanks
I managed to find the solution in the bios. I changed all the fans from DC Mode to PWM Mode and then the led's stay at 100% brightness. I also read on corsair website that they recommend running there new ML fan on PWM Mode so that the fan can properly levitate and thus making it more quiet. Hope this help someone that is experienced the same problems as me this is how I solved my problem.
