Corsair RAM (CMK16GX4M2B3000C15) Overclocking with Ryzen Issue
jkepley538
Just finished my first Ryzen build and working well so far, having an issue getting the RAM speed above 2400. Current stable configuration is using the motherboard D.O.C.P. presets and changing the speed to 2400, anything above 2400 and the system will not POST. I've tried loosening the timings and increasing the voltage using many different profiles, nothing seems to enable me to get a speed above 2400.
System Specifications:
- Ryzen 5 1600 (running at stock speed)
- ASUS ROG STRIX B350-F Motherboard
- Corsair Vengeance PLX RAM (2x8GB) model#: CMK16GX4M2B3000C15
Any recommendations or stable or memory OC profiles for this RAM would be greatly appreciated
Guess this model doesn't belong to Ryzen... Return it and get G Skill ram. Heard several reporting on corsair ram not working well with Ryzen.
Thanks for the recommendation. Unfortunately I used your settings above and the system will not POST. I cant set the speed to exactly 3000 (MB has defined speeds) but tried it at 3200, 3066, 2933, 2800, 2666, none of which worked
