Question Cable for a Corsair RGB HUB ?
Brincanareia
41
Hello and thank you for taking the time to read my question!
Do I need a specific 3-pin or 4-pin cable from Corsair for the Corsair RGB Hub? Or I can use any cable with those specifications?
Thank you for your time and have a nice day! :)
Which Corsair product are you looking at? If you're looking at the Corsair Link range of hardware, they are a unified ecosystem. if you're dealing with older gear, then they need proprietary hubs, connectors and adapters.
Just an FYI, using the wrong cable can ruin your device or the platform.
Reactions: Brincanareia
Hello! and thank you for answering my question!
This is what I have
View: https://imgur.com/a/iEsfnx3
This is what I think I should buy
https://www.fruugo.pt/corsair-rgb-f...Ar1DkUfIwkVgSZdNb4ldSfpHiAUs7_vBoCIosQAvD_BwE
