hi, in the signature you should be able to see my pc build. So, is it normal that while playing project cars the psu fan doens't spin? I mean what does it take to make it spin? I have it since a few months, the psu.
Zero RPM Fan Mode
The efficient design of the RM650 means minimal excess heat generation, so the fan doesn't even need to spin under low to medium loads. And when you're pushing it hard, the thermal sensor controls the fan speed to ensure that it gets the cooling it needs without any extra noise.
Zero RPM Fan Mode
