I recently bought one and it was turning on even using chrome to browse. The fan or something sounded like a small motor, similar to a water pump. Sent it back, installed a new replacement. Now the noise is constant, not on/off like the other one. Not sure what to replace it with, reviews showing the HX850 has coil whine too, It looks like a better choice sine it has 0 fan rpm until it gets to 70c I believe. I might be shipping psu's until I hit the psu lottery and find one that is actually quiet.
Any suggestions for an 850w psu would be helpful.
I'm looking to spend up to $150.
windows 11 home
cpu i9 12900k stock
gpu asus tuf 3080 oc
mb asus tuf z690 e pro
psu corsair rm850e
ram corsair dominator ddr 4, 2x8 gig 3600 hz
ssd samsung 980 pro 1 ter
wd blue
wd black
windows 11 home
cpu i9 12900k stock
psu corsair rm850e
wd blue
wd black
