Corsair Spec Alpha CPU COOLER compatibility
fongj1821
58
https://www.youtube.com/watch?v=EkC2UYsMvUU
I was thinking of getting a HYPER 212 X for this case but it seems when i use PCPARTPICKER it says its not compatible. but when i saw this video, he didnt state what cooler he use but if my guess is right its a HYPER 212 X from coolermaster.
I hope anyone who is using this case may give some feedback or anyone
CHEERS THANKS
Hi, can u please confirm if the hyper 212x will fit without issues in the corsair carbide spec alpha? I was planning to buy the nzxt s340 initially but it isn't available anywhere.
Fits like a charm baby
Hi thanks for the quick reply. If u dont mind me asking.. Are u using the same combo or did you look it up somewhere.. If its the latter then please point me in that direction.. Thanks!
I am using it myself. If u r meaning the 212x with the case
Yeah the hyper 212x with the corsair carbide series spec alpha. Thanks for thw the help.. Much appreciated
U can compare the specs online but I think it's the same model just different fans correct me if I'm wrong
Hi fongj1821,
I got the spec alpha along with Hyper 212 LED cooler . The specs on the alpha suggests that it can accommodate 156 mm coolers.
Like you mentioned you are using a 212 x which is 158 mm and it fits nicely. Do you think there is enough space left in your box as to indicate it can accommodate Hyper 212 LED which is 160 mm in height ? Please let know .
Regards,
Nish26
I Wanted To Know That Will This CPU Cooler Fit in corsair spec alpha
https://www.gigabyte.com/us/Thermal-Solution/AORUS-CPU-cooler#kf
If not then Please recommend one that does and looks like the aorus one
