Corsair Spec Alpha Help
MadG4mer
Commendable
Apr 21, 2016
I was looking through cases and this good looking red/white case pops in my eyes. After I started reading its specs, few problems appeared.
(link to corsair page: http://www.corsair.com/en/carbide-series-spec-alpha-mid-tower-gaming-case-white-red)
1. Is there way to remove hard drive shroud in the front and put 280mm rad in there (example NZXT x61)?
2. My pcpartpicker cant fit larger psu than RM850i (for some reason RM1000i is not in compatible list), is this just some bug in picker?
3. How much cablespace there is behind MB plate?
4. Where can I find fitting cable grommets? (red, white or black)
Thank you!
That case does not support 280mm rads. 120mm/240mm only. Cryorig A40/a40 ultimate would be my pick. The1000w RMi is compatible. I would probably buy the Seasonic built Evga GS 1050, over it though. Grommets I am unsure of. Cable space, you would probably have to search for a review, to find that out.
CPU Cooler: CRYORIG A40 ULTIMATE 83.0 CFM Liquid CPU Cooler ($114.45 @ Newegg)
Case: Corsair SPEC-ALPHA ATX Mid Tower Case ($79.99 @ Micro Center)
Power Supply: EVGA 1050W 80+ Gold Certified Fully-Modular ATX Power Supply ($149.99 @ Amazon)
Total: $344.43
Prices include shipping, taxes, and discounts when...
Total: $344.43
Generated by PCPartPicker 2016-04-22 13:45 EDT-0400
Thank you very much!
