An earlier thread said that the Corsair TX750 had breakaway cables that will fit onto a 4-pin motherboard connection. Will the cables on the TX650 work the same way? Mine have a 6-pin and a 2-pin on the same cable.
I just saw a video on the Corsair site showing me how to split the 8 pin connector. So simple but I never would have tried it! Problem solved -- thanks for your help
