• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
Question corsair tx850 fan problems
speedboat1
9
hi all,
so i've been having a series of random freezes lately--mostly during the load screens of gaming. the display would freeze, a USB disconnect sound would play, and a hard restart would be needed (alternately, the screen would sometimes go black and the computer would restart itself). in either case, the next boot would appear normal.
i combed the event viewer but mostly only found kernel power errors. (one did eventually turn up pointing to the GPU, which i've since disconnected and cleaned--it had quite a bit of dust in it.) SSD is brand new (samsung), and i ran a memory test as well. looking through posts here and elsewhere led me to consider the power supply (corsair TX850) as a possible culprit. as a result, i disconnected that too and tested it--first with the paperclip test, then with a multimeter. the paperclip test showed only that the fan did not start when the psu was on--but given that the TX850 has a variable speed fan, i wasn't sure if this meant anything. the multimeter showed all voltages normal.
with this in mind, i reconnected the PSU and booted the computer (working fine right now, though no gaming, and using the mobo GPU). i then ran prime95 small FFT to test the CPU. temps were really high (~100) so i reduced the OC to a pretty light amount. temps dropped to ~72. i examined the PSU a few times during the prime95 test. on the first occasion, the fan was spinning, so i thought--okay, it's not the PSU. the second time, though, i noticed the PSU fan was not spinning. this was with prime95 running, 100% load. it did seem to be trying to spin, though--a slight rocking or twitching motion, and when i tried a few times to give it a spin with a piece of paper, it started spinning on its own. a few minutes later, i looked, and it was stopped again.
so i wonder a few things:
  • is this PSU faulty? if so, is it serviceable, or better off being replaced?
  • does it seem likely that this kind of problem with the PSU was the cause of my crashes? if not, what else should i check?
thanks in advance for your ideas.
speedboat1
9
i believe it's TXV2. looks exactly like that picture, doesn't have the "M" designation (apologies for the incorrect post title). model number is listed as 75-001311. the PC was originally assembled in 2013, i believe; PSU hasn't been changed since.
just finished as 1.5 hr prime95 test and fan remained off, though PSU case is quite warm to the touch. CPU steady around 79C.
speedboat1
9
thanks reading through / response. can i take this to mean that: yes, this is abnormal behavior for this PSU, and the fan should be cycling on? any way i can test the fan just to be sure, or check PSU temps?
speedboat1
9
okey doke. thanks!
looking at the seasonic focus gm as a replacement. looks like a good buy from poking around on this forum & elsewhere...
speedboat1
9
oof yeah, it's a real graveyard out there. i thought i saw a place where i could get one but it's gone now.
thoughts on the coolermaster masterwatt 750 (not lite, not maker, just vanilla)? looks like a decent budget choice.
