Corsair Utility Engine is broken
BG44097
34
I have contacted their support but they have not replied for 3 days. The program just crashes and all the settings are set to default except the lighting e.g I can't use macros or custom DPI settings.
This has ruined me as I can't play CSGO properly anymore without binds or custom DPI.
I have changed/installed nothing since last week when it appear to be working fine which makes it strange that this has occurred.
I have checked for updates and the program is up to date.
I have some very complex macros that took me a long time to make and I really don't want to have to reinstall. I cannot export the macro files as the program crashes as soon as I click on the 'actions' tab.
What should I try to prevent the program from crashing?
If not where can I find the macro files stored on the C drive? as I could not find them stored in the program files however didn't look very hard.
dont know about macros as havent made any but my saved profiles are in c/users/whatever your user name is/appdata/roaming/corsair/cue/profiles
so look to see if macros also go there
try starting in safe mode to see if you can export them if you didnt find them there
