Corsair vengance rgb pro. Will led's work on a budget b150 motherboard
jaimykoster2001
8
I was planning to upgrade to a new gen i7 (8700k or newer) and was planning to buy corsair vengance rgb pro ram for it. But since i dont have the money for the cpu/mbo upgrade i was wondering if the rgb would work on my msi b150 pc mate ( i dont care about the speed of the memory. just about the lighting )
Yes, the RGB on the RAM kit will work fine in any board. Just an FYI, you can't use an 8700K in a B150 Motherboard, your post seems to indicate that's your plan. Hope this helps! :)
