corsair vengeance 1600mhz help ?
New pc gamer
57
Hi guys I noticed in my msiH81-p33 bios that my ram runs at only 1333mhz and I don't see the xmp to enable it so I just set the ram speed to 1600mhz at 1.5 v and I left the timings on auto is that right like that ? I also ran a memory diagnostic it found no errors
Hi new pc gamer ,
Your motherboard will support 1600mhz ram , but i think natively its 1333mhz as you say
I could not find if your mobo supports xmp so i don't think it does
As long as the timings in auto are the same as those for the ram you should be fine
If you have no stability issues then i'd say you will be ok
