[SOLVED] Corsair Vengeance Pro unstable on Aorus b450i
ishaansphone
Commendable
Jul 31, 2018
4
Constant blue screens with a wide range of error messages each time
Updated all my drivers and Windows
Upgraded from Adata Spectrix D60G (2x8gb) to Vengeance Pro RGB (2x16gb), and now my pc constantly crashes, what should I do?
So far I've tried with XMP off and on, with auto timings and manual timings I've a 2600x, with a BeQuiet 500w power supply, if that helps
I have the option to return the sticks
Thank you in advance
The processor, motherboard, ram(just the capacity, not the model) and the PSU(same story here) have been mentioned in your post. What is the make and model of your discrete GPU and the storage device(s)? Which BIOS version are you on at the moment? Is the PSU recycled?
Thank you for your reply
It's an ASUS TUF 1650s
Crucial P1 500GB nvme
Seagate Barracuda 2tb HDD
I've since had a play around with timings and voltages, and clocking it at 3133MHz instead of 3200, and manually changing the tRC to 55 has fixed it.... For now
Lutfij
ishaansphone
Commendable
Jul 31, 2018
4
