Corsair Vengeance Pro
Dash22
12
Heya, so there is a sale and I need rams.
Which ones should I get for my motherboard Z97 Gaming 5?
Corsair Vengeance Pro Series 16GB (2x8GB) DDR3 1866Mhz CL9
Corsair Vengeance Pro Series 16GB (2x8GB) DDR3 2133Mhz CL11
Corsair Vengeance Pro Series 16GB (2x8GB) DDR3 2400Mhz CL11
Prices are kinda the same, but which one would be the best option on speed/gaming.
Go for the 2133mhz, drop the clocks real tight, it will perform faster than 2400 and 1866 if you drop the Cas to 9 or 10. I bet with those sticks you could even get the Cas down to 8, raise the voltage .5 to 1.55 or 1.6, lower your other timings and you will be golden!
