Corsair Vengeance RAM Problem (BSOD + other problems)
ZettaPC
14
Over the last 6 months or so I have been having problems with my PC. At first I thought it was Windows playing up due to a faulty installation and maybe driver problems etc... However, after researching all the different problems I have had, I'm sure its my RAM. I've had lots of odd problems like Windows gadgets always crashing, process' ending randomly, the whole OS freezing, taskbar jumping about, Nvidia Display drivers crashing. Since I originally thought it was Windows, I formatted the HDD, did a clean reinstall of Windows and all my Nvidia graphic drivers etc and now, X months down the line, It's getting the point were I can't boot at all, or even POST sometimes.
At first I would get Blue Screen errors like, "PAGE_FAULT_IN_NONPAGED_AREA", "MEMORY_MANAGEMENT" & "PFN_LIST_CORRUPT". These would occur shortly after Windows has loaded and when I would load a program or a Steam Game.
So I downloaded 'Memtest86+ v5.1' and let that run for ~6 and half hours and received approximately 530 Errors throughout different tests. I haven't overclocked my RAM at all, or even touched the tweakable settings.
So now I'm in Safe mode w/networking and I received 1 short beep from the speaker, I managed to POST and Boot successfully. This confuses me the most, Is this a combination of drivers problems and my RAM?
I'd appreciate any help,
Thanks.
Well the slots are on the motherboard the memory controller is on the CPU but it is still most likely that the ram itself is at fault. Have you tried running one stick at a time if you have two? Most likely only one bad stick then and the errors would disappear running on the good one.
I have 4 sticks (4x4 GB), I have tried running individual sticks, and I can't seem to find a combination that seems to work without error. I'm going to request an RMA with Corsair.
Thanks for your help.
I ran Memtest on each stick for ~3:00:00. Turns out only one stick has errors. 3 turned out clean and the other had 192 errors after that time. When I was trying different configurations and combinations of RAM, I must of had that faulty stick in there each time. I now have 3 sticks running and I haven't had any problems so far. Reckon I should RMA for that faulty stick?
