N noelski_13 Jul 13, 2018 3 0 10 Jul 13, 2018 #1 Will the 16gb (dual) ddr4 3000 Corsair Vengeance RGB Pro (CMW16GX4M2C3000C15) be compatible with Ryzen 5 2600 and MSI B350m bazooka?
CountMike Titan Oct 31, 2015 35,738 3,878 147,990 Jul 13, 2018 #2 At that frequency all are compatible, just check if BIOS is compatible with second gen Ryzen. Upvote 0 Downvote
N noelski_13 Jul 13, 2018 3 0 10 Jul 13, 2018 #3 Bios, pertaining to the motherboard right? Sorry newbie here. So if my b350m can support ryzen 5 2600, all 3 parts would be compatible with each other? Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,738 3,878 147,990 Jul 13, 2018 Solution #4 Yes sir. Second gen Ryzens are compatible with higher speed RAM. Upvote 0 Downvote Solution
