Corsair VS 650 , Corsair GS600 , Cooler master G600
Adeel Jaffer Jutt
7
I want to buy a power supply for my following system:
1- Core i3 (2120) @ 3.3 GHZ
2- 8 GB Corsair Vengence RAM
3- GTX 550ti ( probably gonna buy r9 270 soon )
4- Intel Motherboard DH67CL
I am currently using Xpert 400 watt psu, which is surely not enough ..!
My options are :
1- Corsair VS 650 - its cheap and easy for me to buy ( PKR-6700)
2- Corsair GS600- its expensive ( PKR 9200)
3- cooler master G600 ( PKR 8200)
I want to play games so please recoomend me acccordingly...! Thanks in advance
You don't have any choice here unfortunately. They are all somewhat bad power supplies. You could put a 750ti on it later with an i5 processor but that's the most I would try to do.
If you hear someone talk about power supply being "good for gaming" , they are just trying to sell you something you don't need. As long as the PSU will run your computer, it will be fine for gaming.
Edit: it might handle the r9 270, but do some research first. :)
I KNOW it will handle the 750ti.
Ok. Can you recommend any PSU from followind site ??
http://galaxy.com.pk/power-supply-pakistan.html
Corsair GS600 is the best of the 3.
It's a teir 2 power supply.
The VS very poor. 🙁
Tier 2 Brands - Top Quality components With Top Notch Stability - For Those With Price/Availability Issues With Tier 1
Antec Neo HE
Antec High Current Gamer Series
Antec EarthWatts greater than 700 watt
Antec TruePower Trio
Antec TruePower Quattro
Antec TruePower New -- 750w
Akasa PowerGreen 80+
CoolMax CTG-750 watt/850 watt/1000 watt
Cooler Master Ultimate/UCP
Cooltek CT
Corsair GS600 / GS800 :bounce:
Corsair HX
Corsair RM 550
Corsair TX
Corsair VX
Cougar SX700 and GX700
Enermax Liberty
Enermax Infiniti
Enermax MaxRevo 1350
Enermax MODU82+
Enermax Platimax (600, 750, 850, 1.2K)
Enermax PRO82+
Enermax PRO87+ (500w + 700w)
Enermax Triathlor (550, 650, 700)
Enhance ENP-GH
Fortron (FSP) GLN
Hale82-m 650-750w
iStarUSA PD2
iStarUSA PD3
LEPA G500
OCZ EliteXStream
OCZ Fatal1ty
OCZ GameXStream less than 1000 watt (only if manufactured in December 2007 or later)
OCZ StealthXStream 400 watt
OCZ StealthXStream 2 greater than 700 watt
OCZ Modstream (only if manufactured in December 2007 or later)
OCZ EvoStream
OCZ ProXStream
OCZ Z(t)(s) Series Less than 1000W
OCZ ZX 850w
PC P&C Silencer less than 610 watt
PC P&C Silencer MkII
Rosewill Capstone (450, 750)
Rosewill Fortress
Rosewill Hive (550, 650)
Seasonic G series
Seasonic S12
Seasonic M12
Seasonic Energy Plus
Sentey Golden Steel Power 850w
SevenTeam ST less than 600 watt
Silverstone OP/DA 700 watt or less
Supermicro/AbleCom
Thermaltake Toughpower greater than 600 watt
Thortech Thunderbolt Plus 800w
Topower Powerbird 900w
Xclio StablePower
XFX Core Edition
Xigmatek MC
Xigmatek HC
Ultra X3
Ultra X-Pro
Zalman ZM less than 1000 watt
Yes Corsair GS600 is best but check the price tag also.. its 2.5k more costly than VS650. All I want to ask is " if Corsair VS650 is best suited for gaming and for my future updates like r9270 and core i5 ??
