Corsair vs350 psu is too low for this system?
yuffie1991
Hi all, i'm throwing together some old/new component and i was wondering if vs350 was enough to power the system:
-gpu: GeForce gtx 560
-cpu: Intel Pentium G4560
single ram stick ddr4 and ssd
is it cutting too close as wattage?
keep in mind it will mostly be used for low graphic gaming (like league of legends)
or some photoshop.
If for any reason the psu doesnt keep up it should just cut the power and power down the pc, is that right?
In the best case scenario, yes.
On all others it can damage your other parts.
Do as said above, grab at least a CX450M, SeaSonic S12 520W, or any Tier 2 PSU
I know it's not the best psu but is one of the piece i had on the side, so i was wondering if it was a possible solution without having to buy another one...
thx for the answers
Latest posts
