C Clique Commendable Nov 6, 2016 6 0 1,520 Nov 6, 2016 #1 Quick question: I plugged the pump header into Cpu_fan1 -- should speed setting be at 100% for this? The radiator fans are all controlled via a fan curve.
Solution Gam3r01 Nov 6, 2016 Pumps should generally run at 100% in CLCs, Typically I recommend plugging them into SYS_FAN headers so you dont have to worry.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 6, 2016 Solution #2 Pumps should generally run at 100% in CLCs, Typically I recommend plugging them into SYS_FAN headers so you dont have to worry. Upvote 0 Downvote Solution
