Corsair XMS3 (2x4GB) Work with M4A78LTM Motherboard?
Mitchellarr
7
Will the two work?
Here are the links.
Corsair Memory: http://www.amazon.co.uk/Corsair-CMX8GX3M2A1333C9-XMS3-Memory-Module/dp/B003N8GVUY/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I338RPVCKG1A9S&colid=17NMEKJJCTHVZ
Asus Mobo: http://www.asus.com/Motherboards/AMD_AM3/M4A78LTM/#specifications
My specs are:
Operating System
Windows 7 Home Premium 64-bit SP1
CPU
AMD Phenom II X4 965
RAM
4.00 GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
Motherboard
ASUSTeK Computer INC. M4A78LT-M (AM3)
Graphics
X193W (1440x900@60Hz)
ATI Radeon HD 5450
Hard Drives
488GB SAMSUNG SAMSUNG HD502HJ ATA Device (SATA)
Mitchellarr
7
Just in case you need it, Sorry i Missed it out:
Power Supply
Standard 300Watt (Upgrading to an XFX or Corsair 500/600+Watt soon)
(Graphics Card: Will be upgrading along with Power supply soon, hopefully to a 6770)
Mitchellarr
7
I installed the ram an hour ago, turned the PC on, and there was no video signal, all USB and audio jack peripherals were working (on), and the computer itself had all powered up.
So why did the monitor not show a signal, Too little power? :S I did ask in other forums whether my specs would run it, they all said yes.
I did check to see if the monitor or cables were incompatible, even removed all but these two things. I attempted changing them round, checked, double checked. Nothing worked.
Thanks in advance :(
