[SOLVED] cougar mx330 help
Guess that you mean the frontpanel itself,can't say more than "that's what vacuum cleaners are for". Not even try to be amusing here.Can maybe use an old toothbrush or rigid paintbrush to get stuff loose.
i manged to do it but it only open the way to the fans, the dirty mash itself is still behind the steel "cage"
