Question Cougar MX330-X Front Panel USB Addition Help
Apr 24, 2020
I have purchased a Cougar MX330-X case for my first PC build and noticed that the front I/O panel has slots for 4 USBs but the hardware that is there only has 2 USBs and the other two USB slots have pieces of plastic blocking them off. I would like to add 2 more USB-A (preferably USB 3) ports for those empty slots, with only a USB 3 Gen2 plug open on the motherboard, but do not know the technical terms to find what I am looking for. The empty USB ports are close together and parallel in the long direction, if that helps at all.
Does anybody have a recommendation for this particular addition to my Cougar MX330-X case?
