Cougar panzer max case - system panel cables polarity marking?
shawnzhu
15
Hi guys,
I'm just building a new system, and I'm using the Cougar panzer max case with an Asus Z370-H MB.
I'm bit confused when connecting the system panel cables came with the case to the system panel connectors on the MB, as the connectors (HDD LED, Reset, and PWRSW) on the cables don't have +/- marked.
Do the +/- matter when connecting HDD LED, Reset, and PWRSW connectors? If they do, any one knows how the +/- marked with Cougar panzer max case system panel cables? The user manual came with the case was quite brief.
Thank you in advance.
It doesn't matter for switches, only for LEDs but nothing bad would happen if you switched polarity. If it doesn't light up, just reverse connections.
