[SOLVED] Cougar QBX build question
Mar 5, 2019
4
Hi guys, im gonna build a pc for the first time ever. I dont know much but a couple of friends help me pick out component for my mini itx build. Here are the list https://pcpartpicker.com/list/hbZ6fH
A lot of people having trouble picking the psu and i want to know if it will fit. And is the build ok?
Thanks in advance guys.
Something like this? Also If you're not overclocking you can use the stock cooler. Or if you are, buy a high end air cooler like a Noctua if you need to know off a few bucks.
CPU | AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor | $144.89 @ OutletPC
CPU Cooler | Corsair - H100i PRO 75 CFM Liquid CPU Cooler | $104.89 @ OutletPC
Motherboard | MSI - B450I GAMING PLUS AC Mini ITX AM4 Motherboard | $119.99 @ SuperBiiz
Memory | G.Skill - Ripjaws V 16 GB (2 x 8 GB) DDR4-3000 Memory | $94.99 @ Newegg
Storage | Crucial - MX500 500 GB 2.5" Solid State Drive | $69.95 @ Amazon
Video Card | MSI - GeForce GTX 1060 6GB 6 GB GT OCV1 Video Card | $254.89 @ OutletPC...
Feb 15, 2019
26
4
35
What are you building it for, and what is your budget? For gaming i would recommend 3000 mhz speed memory atleast. And with that card you don't need a Ryzen 2600. The case is decent but will only support a psu of 140mm or under.
Mar 5, 2019
4
Im building it for casual gaming i dont need the ultra quality but enough to run latest game with decent graphics. I will change the memory. Do u have any psu that you can recommend?
Feb 15, 2019
26
4
35
Power Supply | SeaSonic - FOCUS Plus Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply | $69.99 @ Newegg
| Total | $859.59
4
I already bought the ryzen 5 2600 and a ssd 500 lol and since i live in quebec..the price wont be the same thats why im getting 1050 ti x__x so with the build i wanted..would a psy 650w enough?or do i really need 750w? Sry i might ask dumb question but just want to make sure everything will be ok
Feb 15, 2019
26
4
35
A 650w should be fine as long as it is a high quality like the one i put. You really could put a 500w or 550w but they are lower quality.
