Couger Vs Noctua - Which is better for case and heatsink fans?
SimplyCurious
117
I'm currently planning to upgrade my case to a enthoo luxe and to buy some after market fans with it.
Right now, I'm torn between the Noctua IPPC line and the Couger CFD led fan series.
I'm wondering what is the best fan for overall airflow and temperatures, and sound doesn't matter.
Thanks for the help :)
SimplyCurious
117
Doesn't the couger have leds? Would you suggest just getting the cougers or just getting the noctuas with an led set
SimplyCurious
117
Are they better than the Corsair AF or SP fans? And If the cougers cost that much, do you think they have a better price/performance? Also what is your build with the cougers, wondering how good the temps are
Karadjgne
Herald
Cougars make good case fans and are relatively cheap. Noctua makes better case / radiator fans but cost more. @900 rpm both are quiet, above 1000 rpm cougars get much louder. Noctua doesn't do leds. If you want good led case fans with good cfm, look at bit Fenix pro lines.
Similar threads
