Hello
I would like to ask, if its possible to PSU slowly going to die. Now let me explain why i guess.
My PC Specs :
CPU : AMD Ryzen 9 9950X3D (OC to 5.2GHz)
CPU Cooler : Arctic Liquid Freezer Pro - 360
RAM : 4x48 GB RAM - Kingston Fury ( all 4 sticks ), 6000 MHz, CL30
MB : ASUS Crosshair X870E Hero
PSU : Corsair RM1000x ( 3 months old, was factsory new )
SSD : 1x Samsung 2TB 9100 Pro, 1x Samsung 4TB 990 Pro
GPU : Gainward GeForce 5070 Ti Phoenix ( not even 14 days old )
Problem started 2 days ago. I am just chillin and playing Path of Exile, which there was suddenly BSOD without any warning or any reason. I told myself, okay [Mod edit to remove profanity. Remember that this is a family friendly Forum.] happens. Its maybe because of game. So i started play again POE - now it was reboot PC after a while of playing. So this kinda sounds suspicious. So i tried some benchmarks (3D Mark, Unigine SuperPosition) and everything was OK. So i tried CPU test (OCCT - CPU test), Cinebench 15 & 23 - everything ok. Temperatures was also ok on GPU and CPU.
But... There comes the mystery. When i tried hardly using system, or hardcore Power test in OCCT - It takes about 600W (CPU+GPU), and from this situation there is always freezee and i must do a hard reset. Problem is its sometimes it freezee at 30s, sometimes after 2 minutes, but still same scenario.
What i tried at all.
1) Reinstall chipset AMD drivers
2) ADD voltage to CPU (tried default - same result)
3) Update BIOS to the latest one ( 1512 )
4) Underclock and power limit on GPU on lowest possible (power limit)
5) Check if there is something with SSDs, they are perfectly working.
6) Tried Memtest (all 4 pass), OCCT - MEM, and CPU+MEM no errors
7) Tried other game if situation occurs again. It not happens, but i am not gonna blame Path of Exile, because of Power Test in OCCT is a proof - where something is dying or almost dead.
I really think there is a PSU suspicious component, which is going slowly to die or its just mine feeling and it could be something else?
I cannot try the PSU on other PC, because other PC is low-end without power usage more than 250-300w at nax,
I do not have other PSU to test in my PC, if its OK or no.
There is no crackling or some kind of sounds from PSU.
I am lost, do you have any ideas how to resolve this annonying and little dangerous situation?? If its PSU i can buy other, but i am not sure if it is the reason of hard freezee in test.
Thanks for your tips.
My PC Specs :
