Just a thought but I have a H115i and of course that did not fit in my case.. and I have a big one.. I had to mod the case.. so IF it does not fit and you are good with some tools I would say it could fit in just about any case. like my little larger cooler then your one you have mentioned what I did was install it on the back externally on the back of the case.. so the fans and radiator are out the back.. I used the original spot for the one fan and cut it out larger to fit the larger case fan then the top fan on the case is above the case (with a little exception of the plastic top of the case I modified that so some of the air comes in below and some above the case.. so about 20% of the radiator is completely above my computer case...
