Could I upgrade my graphics card, and what card?
ocake
4
I'm new to upgrading hardware, and I want to upgrade my graphics card to something that can run DayZ, Rust, etc. at decent settings.
Here's my system's spec's:
Motherboard
Model: Asus CM1745
BIOS: American Megatrends Inc. - 5007 - 08/27/2012
CPU Socket: Socket FM2 (904)
North Bridge: AMD K15 IMC rev 00
South Bridge: AMD A85X FCH rev 2.4
Graphic Card
GPU Type: AMD Radeon HD 7400M Series (750 MHz)
VRAM Size: 1024 MB (667 MHz)
Processor
Name: AMD A8-5500 APU with Radeon HD Graphics
Threading 1: CPU - 4 Cores - 4 Threads
Frequency: 1399.67 MHz
Thanks! :)
i reccomend saving a little more money to get something like this: it will provide alot better performance. getting such a low end card may not provide much benefits, since the a series gpus are pretty decent anyway. it would be more of a side step than step forward.
anyway, heres my suggestion, its gonna be nearly twice your budget however.
Video Card: XFX Radeon R7 260X 1GB Core Edition Video Card ($109.99 @ Newegg)
Power Supply: Rosewill Hive 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.49 @ Amazon)
Total: $169.48
Generated by PCPartPicker...
whats your power supply? without knowing it, i would reccomend at most a 750ti without power connectors.
we also need a budget to reccomend a good gpu. you may need to buy a psu to support the new card as well. the best card id get with the a8 without overclocking and slight bottlenecking is a gtx 760 or r9 280.
I have a 286 watt power supply.
Also, I apologize, I forgot to include my budget. Which is $90 for now.
Not trying to sound cheap or anything, but would a GeForce GT 610 be able to be put in my computer? And would it run good?
Asus CM1745 pre-built.
Total: $169.48
Generated by PCPartPicker 2014-08-10 23:25 EDT-0400
i seriously suggest getting a better psu before upgrading anything else. psus that come with prebuilts are garbage. i wouldnt trust the lowest watt requiring gpu with the psu in there
Will do, thanks for the help! :)
