Could it be possible if the input (little hole) of where I put charger in is damaged?
can you specify the problem clearer? 50-50 you need new laptop if you do broke it, you can just probably take it for service, if it possible to remove the power input from motherboard, cost should be cheaper, but if not, there could be a chance that the motherboard has to be replaced, sometimes replacing components could be as expensive or almost as expensive as buying the new laptop itself. you might consider about that
