[SOLVED] Could my CPU be damaged from prolonged heat?
kilo24
83
Even Half-Life 1 on low settings underperforms on this computer (i5-3570k, gtx 1050 ti) and since my temps have apparently been going slightly above 100C while a game is running, I've ordered a new CPU cooler. I thought this would fix the performance issue but it seems it won't (hasn't arrived yet) because this CPU doesn't throttle until 105C, which it doesn't always reach. My main question is: could the CPU be damaged and thus underperforming overall due to being this hot for who knows how long (it was built in 2012)?
Then a simple removal/reapplication of thermal paste (and a blowout of dust) may well be sufficient.
Not saying damage can't be done, but under the circumstances, it may simply be the cooler more than anything else.
Voltage is more of a concern vs strictly heat. There are certainly risks involved once you run higher temps sustained (see link above), but it's doesn't sound like you've been running an overvolted, overclocked CPU that's been throttling for years - so you *should* be ok.
While the max temp is 105'C before throttling, it's highly recommended to keep a chip much cooler than that for 24/7 usage.
<80'C would be where you *should* be.
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
However, when was this cooler installed? Assuming it's the stock Intel offering? Either way, have you ever removed dust/reapplied thermal paste in the 6-7 years it's been running?
