Hello, I recently upgraded my small form factor mini ITX computer with a new GPU (GTX 1070), CPU cooler and a new (600 W) PSU. I am experiencing a high CPU temperature of 100°C and a choppy frame rate on games. I ran MSI afterburner while playing GTA V to see that my core i5 4690k would get up to 100 °C and the 4 cores of the CPU being around 95~99 °C. I am more than sure that this is too hot for a CPU to run and is causing it to throttle. (Well that's my theory on why I believe I'm getting such a choppy frame rate.) My GPU temp never went over 80°C. And I know that's not hot enough to cause the GPU to throttle. I have done several clean installs of drivers. I have made used that all old drivers were removed. I have reverted back to older drivers and it made the game less choppy, but still choppy. I have put in an older GPU (gtx 960) and the frame rate was choppy as well even dropping to single digit fps. I took off the aftermarket cooler and replaced it with the stock cooler and still the CPU temps were at 100°C. I have also replaced the RAM. I have read several forums on here and tried their methods, but nothing seems to work. I tested another game The Division, and the frame rate was still choppy and would dip down to the single digits. I have turned off V Sync and turned it back on several times in each game and limited the fps to 60 and the frame rate still becomes choppy and is not smooth. None of the games ran on ultra settings only on high. Game benchmarks came back with average 60 fps on both games. My CPU is not overclocked and is running at its stock CPU speed.
Here's what's in the case
Core i5 4690k, stock cooler
Zotac Mini gtx 1070
Silverstone SFX Series 600 W PSU 80 plus gold
Kingston HyperX DDR3 16 GB RAM
Toshiba 1 TB HDD 7200 rpm
Intel H81 Motherboard (I believe, it was pre-installed)
PC used to be a Syber Vapor P-W Pentium with the pre-installed parts.
Zotac Mini gtx 1070
