Hello Everyone!
I hope I've put this in the right section; I couldn't really find a topic related to audio/sound that was for computers, so thought it would fit into the component section.
I've recently swapped back from using my in-built audio on the motherboard, to an Asus Xonar DX, with my Roccat Kave 5.1 Headset.
I've been told that when using VOIP services, such as Skype, Mumble or Teamspeak, that there is a large static noise in the background (been told by one person it sounds like I'm sitting next to a bi-plane.)
I've done a test call on skype, and it is indeed there in the background (it gets louder and louder, but when I speak/make a sound it drops the static back down to a minimum).
I recently tried to test this on twitch.tv, examples of which can be found here:
http://www.twitch.tv/novainfuse/c/2479681
When I look at the levels on my streaming software, such as Xsplit or Open Broadcast I can see the levels on the mic showing, even when I am muted or not talking. This is also the case when I remove all sounds from my room (bar my fans, which are quiet and do not make the noise on the mics). Furthermore, when I look at the mic in Control Panel - Sound, I see no change in the levels at all.
It is the only device, audio related, plugged into my computer. I have speakers, unplugged, sitting next to it.
My specs are:
Windows 7 64 Bit
Nvidia GTX 570
Intel Core i5-2500k CPU
8GB Ram
Can't seem to find my motherboard in the Dxdiag, but if I recall, it is an asus.
Thanks in advanced!
My specs are:
Windows 7 64 Bit
Nvidia GTX 570
8GB Ram
Thanks in advanced!
