could someone comment on my build?
Dreampoacher1
7
Runs good just want some comments/suggestions for change/ upgrade, thanx in advance.
Operating System
Windows 7 Professional 64-bit SP1
CPU
Intel Core i7 3770K @ 3.50GHz 35 °C
Ivy Bridge 22nm Technology
RAM
32.0GB Dual-Channel DDR3 @ 686MHz (9-9-9-24)
Motherboard
ASUSTeK COMPUTER INC. P8Z77-V DELUXE (LGA1155) 30 °C
Graphics
ASUS VS247 (1920x1080@60Hz)
2048MB ATI AMD Radeon R9 200 Series (XFX Pine Group) 33 °C
Storage
119GB SAMSUNG SSD 830 Series ATA Device (SSD) 25 °C
1397GB Western Digital WDC WD1502FAEX-007BA0 ATA Device (SATA) 30 °C
1397GB Western Digital WDC WD1502FAEX-007BA0 ATA Device (SATA) 31 °C
223GB TOSHIBA MKNSSDCR240GB-DX ATA Device (SSD) 32 °C
Optical Drives
ASUS BW-12B1ST ATA Device
Audio
Realtek High Definition Audio
I never even processed that when I was reading the spec, good eye, teaches me to look out for more when reading specs like this :) thanks.
I love the look of R4, I'm excited to try out the windowed version, loads of room for a novice like me to dive into and hopefully have a long lasting case.
You have a lot of storage, are you using any RAID configurations at all, or...
Btw, did you actually build this? Sounds like you just copied what the computer said it had...
That's a fair bit of hardware, do you do a lot of video rendering/editing?
Mind if I ask what that build cost you?
From my novice view, depending on the function, it's the GPU most likely that would be the next thing to upgrade, if your system even ever needed an upgrade. Other than that you'd just be updating with newer versions of what you are already running.
Do you game at all? You say it runs good, I'm curious what you are putting it to work doing :)
You have a lot of storage, are you using any RAID configurations at all, or are they just extra storage you found you need for your purpose? Forgive all the questions, I'm simply fascinate.
Havent used raid in this sys.,the bigger hard drives are my older ones that I use just for pictures and extra stuff after the ssd starts to fill up. Samsung ssd for system and mushkin for gaming. thanks for all the feed back everyone. I am fascinated with computers, never went to school for it just love "playing" around with them.
