• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Could someone tell me if my parts are compatible?
kessingar
8
Motherboard:Asus Strix B250F gaming motherboard
CPU: intel core i7 8700k
Ram: Corsair vengeance LPX 16 GB (2 x 8)
GPU: gigabyte GeForce gtx 1080 founders edition
SSD: Samsung 850 EVO 1 TB 2.5 inch
Power Supply: Corsair 850 W 80 plus gold certified modular
CASE: Corsair graphite series 780T full tower
kanewolf
What features besides compatibility with the 8700K are important? RGB lighting? WIFI? Form factor? pcpartpicker.com can allow you to compare COMPATIBLE products. I would recommend you spend some time "playing" on that site.
kessingar
8
I’m not looked for many features maybe just vr combatability. Not really bothered with rgb. And I couldn’t see some parts on pc part picker. So would the cryorig h5 be good for my needs?
maxalge
Champion
Herald
the h5 is not strong enough if you ever want to play around with maxing overclocking the cpu, but will function properly if you run it stock or mild OC
get the r1 ultimate if you dont want it to be the limiting factor
you dont need a 850w power supply, drop down to the 650w model, it will have plenty of headroom
I would go with the asrock Z370 Extreme4
maxalge
Champion
Herald
drop down to a good 550w power supply
if you dont intend to overclock then no point in anything bigger
you should also get the i7 8700 NON "k" and use the stock cooler
kessingar
8
and what fps would this pc run on 1080p or 4k on lets say GTA V?
maxalge
Champion
Herald
the 1080 is not really a 4k card
you want at least a gtx 1080 ti for that
at 1080p the gtx 1080 can easily damn near max out gta with over 60 fps ( you will need to turn off/lower some advanced settings )
kessingar
8
and as i am new to this is there anything that would make this run better for gaming? i only have a budget of around 2000 euro. i think that's round about 2450$. like is there anything on my list that makes another component overkill or bottleneck
Similar threads
