Hello and thanks for reading,
As the title says I'm having an issue on CS:GO it looks like a video problem or lagspikes issue, but it does not get reflected on net_graph 1, as fps are above 120 at all times and latency is around 60 for most servers i play on with no loss and no choke. The issue is when i play i can see some frame skipping like the guys teleport not too long but i don't see a smooth animation like i should given its supposedly at 120fps, sometimes i run and get backed a bit i heard some guy call it "rubber banding"
My specs are at the bottom my ISP is xfinity comcast at 20mb the bad part i think is that a use a negear N300 usb wifi appliance since the router is in the second floor and I'm not allowed to use my ethernet cable.
any thoughts or possible solutions are welcome, can't do anything about the wifi... I also use google DNS it improved a lot the latency on all games.
