Counter Strike Global offensive low fps problem.
Ivan Gonzo Ivanov
7
Hello everybody. So my actual problem is that i expected more from my PC, i mostly play CS:GO and i expected around 300ish + FPS but im not even near that. I have watched videos of ppl playing around 300. I'm using FX-8350 and GTX 760, but i cant gear a higher framerate than 160 ~~ and it keeps dropping sometimes when i play.Temps are not problematic, GPU gets around 55-60 and CPU around 68~. Any help would be apreciated.
playing games isn't about having 300+fps , its about playing without having issues ,i play CS:GO on 90fps although i got Asus 144hz monitor and a decent pc ,since everything looks fine at 90 or 120 or w/e fps ,then there is no need for those additional fps .it's better to max every graphic setting and lowering the fps_max to 90 or 150 or in between .
hope this helped and gl
