counter strike GO graphic problem
Pushkraj_1
Commendable
Apr 11, 2016
21
my pc specs are :
Operating System: Windows 7 Ultimate 32-bit
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: G41M-ES2L
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz (2 CPUs), ~2.1GHz
Display Memory: 1294 MB
Dedicated Memory: 32 MB
what are best settings to run the csgo game
The motherboard has an onboard graphics solution.
It will not be powerful enough to run CS GO with a good frame rate and graphical effects turned on to high or medium settings in the game.
You motherboard has a Pci-e graphics card slot on it.
I suggest you look into buying a Pci-e based graphics card first before you buy CS GO to play on your computer.
You can pick up a mid range Pci-e graphics card for your system that will play the game quite well.
You would find one for a decent second hand price through e-bay or something like it if you are not willing to pay for a brand new card.
Pushkraj.
You're going to need an actual graphics card if you want to play the games at high FPS. Your computer is generally pretty old, so the integrated graphics card isn't that good.
Pushkraj.
